HI LAMMPS users,
I have to simulate two systems A and B,
system A includes full 1-4 interactions ( 1.0) & system B doesn’t include 1-4 interactions
pair_syle is buck/coul/long.
Can anyone advice me how to set up system?
Thanks in advance
Karteek Kumar
HI LAMMPS users,
system A includes full 1-4 interactions ( 1.0) & system B doesn't include
1-4 interactions
you cannot. that is, not without a significant amount of programming.
1-4 exclusions are handled/assigned during neighborlist creation, you
would have to write your own code to do this and figure out a way to
determine, which interactions belong to each part, etc.
Thanks Axel,
As posted here by Andrew,
http://lammps.sandia.gov/threads/msg34877.html
For A type molecules (which include 1-4) and B type (doesn’t include 1-4)
Can I do the following,
use special bonds
for B-type, add pseudo bond between 1-4 atoms, and cancel out lj interactions by applying force and energies with bond_style table.
Karteek Kumar
Thanks Axel,
For A type molecules (which include 1-4) and B type (doesn't include 1-4)
1) use special bonds
2) for B-type, add pseudo bond between 1-4 atoms, and cancel out lj
i don't think so. you add a new bond and with it new exclusions.
The above one is not working, adding an extra bond for 1-4 with table potentials to cancel out 1-4 interactions.
Surprisingly, I can see some atoms coincide with each other which is very unlikely.
( I didnt added 1-3 bond interactions via special bonds and not added 1-3 bond)
Karteek Kumar
unlikely.
bond)
but by adding this bond, you turn what was a 1-4 interaction into a
1-2 interaction (which takes precedence) and you create additional 1-3
and 1-4 pairs.
