3D Poiseuille flow of MD by using lammps
I am using lammps to simulate the 3D Poiseuille flow. My model is a cubic and I use the fix addforce command to give each atom a force which is along with x direction. Unlike the other 3D poiseuille flow, there are two walls used to confine the fluid zone in y and z direction respectively.
However, when my code is run about 500,000 timesteps and there is an error “ERROR: Lost atoms: original 20480 current 19873 (…/thermo.cpp:442)”. I found that some fluid atoms will pass through the solid wall by outputting the number density of fluid atom using commands “compute mychunk1 flow chunk/atom bin/1d z 1.635 0.545 units box” and “fix result1 flow ave/chunk 2 2000001 5000000 mychunk1 density/number temp bias mytemp file result1.out format %20.16g”.
My input file is shown as follows. I will be grateful if you can help me fix this problem. Looking forward for your reply.
units nano
variable T_fluid equal 300
variable T_wall equal 300
boundary p f f
atom_style atomic
neighbor 2.0 bin
neigh_modify delay 1 check yes
#geometry create
lattice fcc 0.545
region box block 0 20 0 16 0 16
create_box 2 box
create_atoms 1 box
mass 1 6.6335209/1e5
mass 2 6.6335209/1e5
#define groups
region 1 block 0 20 3 13 3 13
group flow region 1
group boundary subtract all flow
set group boundary type 2
#initial velocities:
velocity boundary create ${T_wall} 99999 dist gaussian mom yes
fix wall_force boundary spring/self 70e3
velocity flow create ${T_fluid} 99999 dist gaussian mom yes
#L-J potential
pair_style lj/cut 0.85125
pair_coeff 1 1 1.657 0.3405 0.85125
pair_coeff 1 2 1.657 0.3405 0.85125
pair_coeff 2 2 1.657 0.3405 0.85125
#control the temperature of wall
compute temp_wall boundary temp
fix wall_1 boundary nve
fix wall_2 boundary temp/rescale 50 {T_wall} {T_wall} 0.1 1
#definition of flow
fix definition_flow flow addforce 10.0 0.0 0.0
#control the temperature of fluid
compute mytemp flow temp/com
fix flow_1 flow nve
fix flow_2 flow temp/rescale 50 {T_fluid} {T_fluid} 0.1 1
fix_modify flow_2 temp mytemp
#output results
compute mychunk1 flow chunk/atom bin/1d z 1.635 0.545 units box # the zone of 0.5453=1.635<=z<=0.54513=7.085 is the fluid region.
compute mychunk2 flow chunk/atom bin/2d x 0.0 0.545 z 1.635 0.545 units box # the zone of 0.5453=1.635<=z<=0.54513=7.085 is the fluid region.
fix result2 flow ave/chunk 2 2000001 5000000 mychunk2 density/number temp bias mytemp file result2.out format %20.16g
#run
thermo 20000
thermo_modify temp mytemp
timestep 1e-6
run 5000000
Best wishes,
Qiangqiang Sun
in.flow (1.79 KB)
