I want to use the solid-liquid interface technique to determine the melting temperature of a
LJ liquid.
I want to do this by having a large simulation box, with the liquid at the bottom
and the solid at the top, visually inspecting the movement of the interface,
Using the idea from J. Morris and X. Song, J. Chem. Phys. 116, 9352 (2002).
My problem is, the second read_data command doesn’t add the atoms to the specified region.
Could you please point to what am I doing wrong?
in the google drive link are the two dump files in compressed form and the practice
script i’m using “in.Tmelting_snapshot”.
https://drive.google.com/open?id=0B4_1VwCLMtkcREVrckJYalZuLUk
I want to point out, the script isn’t the full simulation script,only the part where I use read_dump
and afterwards the dump command to visualize my system.
My second question is about the example of melting temperature of aluminium in the
scripts and howto section:
http://lammps.sandia.gov/user/script4/in.two_phase_simulation
In this script, the author deletes atoms from the simulation box and my question is why?
Thank you,
