A Mismatching in Pair Potential Energy Measurement
Dear LAMMPS Developers and Users,
I have a 3d system of 500 charged particles interacting via Yukawa Pair potential. I am using the NVT thermostat (using ‘fix nvt’ command) to equilibrate the system at desire temperature. I am calculating the total potential energy and pair energy (both are equal for this case, as expected) using the following commands:
pair_style yukawa {kappa} {cutf}
pair_coeff * * 3.2891e-20
thermo_style custom step temp pe epair
thermo 500
Beside that, I have also dumped all the positions and velocities by following command:
dump dp1 all custom 500 dump_nvt.lammpstrj id type x y z vx vy vz
By knowing the positions of all the particle at a given time step, I can calculate total pair energy of the system at that time step by calculating
sum_(i,j) [(A./r_{ij}).*exp(-{kappa}.*r_{ij})] ,
With the condition " r_c(cutf) >= r_{ij} > 0 "
where r_i = sqrt((x_i).^2 + (y_i).^2 + (z_i).^2) and r_{ij} = abs(r_j - r_i)
I expected potential energies from these two different methods should be same or might be different by a constant normalization factor, which will be indipendent of ‘kappa’. But I am not getting this. Am I missing any conceptual issue by doing the calculation of pair potential energy?
Any help or suggestion will be appreciable.
I am using ‘lammps-17Nov16’ version of LAMMPS.
Thank you in advance.
With regards
Srimanta Maity
Institute for Plasma Research, Gandhinagar, India
potential. I am using the NVT thermostat (using 'fix nvt' command) to
pair_style yukawa \{kappa\} {cutf}
thermo 500
following command:
vy vz
r_i)
1) Is this a periodic system? Did you remembering to consider
periodic images in the summation above?
indipendent of 'kappa'. But I am not getting this. Am I missing any
2) One suggestion would be to compare differences between the energies
of two different conformations, rather than the absolute energy. You
can add a constant to the energy without effecting the physics of the
simulation.
3) Are you using pair_modify shift? (this will add a constant to the
energy of the system)
4) You can ask LAMMPS to generate a table of energy (and force) as a
function of inter-particle spacing (r) using the "pair_write" command.
5) This does not effect you, but (generally speaking) if you are using
a pair_style with a long range electrostatic contribution, then you
have to consider the contributions from periodic images carefully.
That's what comes to my mind.
I don't know if this helped at all.
Cheers
Andrew
Thank you for your suggestions. Yes, I have missed to point out that I am using periodic boundary condition in my simulation. Here I am using Yukawa pair potential, which is a short-range interaction limited up to the distance r = r_c (force cutf). So in this particular case, I wonder is it necessary to consider periodic images in the summation?
No, I am not using “pair_modify shift” command. But I have used the “pair_write” command to get the profile ® of pair energy which is exactly matching with the analytical expression [(A./r).*exp(-{kappa}.*r)]. But it does not give me the total pair potential energy of the entire system.
Thank you
With regards
Srimanta
yes, ​absolutely​. please grab your MD text book and look it up.
