I am trying to do nanoindentation using the diamond indenter on polycrystal and amorphous nickel, respectively. The eam potential for the Ni and L-J potential for the interaction between Ni and C. No force field parameters are set between C-C.
However, there seem to problem with my code. When the indenter contacts the metal surface, a very very large force is generated, it must be a wrong result.
In some places in the code, the use of symbols for calls would cause the published font to change, so I removed some of the call symbols.
This is the code:
boundary p p s
atom_style atomic
read_data model.data extra/atom/types 1
mass 2 12.01
lattice diamond 3.57
region 4 sphere 50 50 150 30 units box
create_atoms 2 region 4 units box
group indenter region 4
set group indenter type 2
mass 1 58.69 #Ni
pair_style hybrid eam/alloy lj/cut 10
pair_coeff * * eam/alloy Ni.eam Ni NULL
pair_coeff 1 2 lj/cut 0.0486 2.964 #Ni-C
pair_coeff 2 2 none
timestep 0.0005
neighbor 0.3 bin
neigh_modify delay 2
dump mini all custom 50 mini.dump id type x y z vx vy vz
minimize 1.0e-10 1.0e-10 10000 10000
undump mini
write_data opm.data
region 1 block INF INF INF INF INF 10 units box
group boundarylayer region 1
region 2 block INF INF INF INF 10 20 units box
group thermostatlayer region 2
region 3 block INF INF INF INF 20 100 units box
group newtonianlayer region 3
group mobile subtract all boundarylayer
fix 1 all nvt 300 300 0.1
velocity boundarylayer set 0 0 0
fix 2 boundarylayer setforce 0.0 0.0 0.0
velocity thermostatlayer create 300 5812775 temp thermostattemp
fix 3 thermostatlayer temp/rescale 10 300 300 10 1
fix_modify 3 temp thermostattemp
dump 1 all custom 1000 nvt.xyz id type x y z
run 60000
write_data relax.data
fix 1 thermostatlayer nvt temp 300 300 0.05
fix_modify 1 temp thermostattemp
fix 2 newtonianlayer nve
fix 3 boundarylayer setforce 0.0 0.0 0.0
displace_atoms ball move 0 0 -15 units box
variable depth equal 30
variable gap equal 5
variable load_step equal 35/0.5/0.0005
variable pos equal xcm(tool,z)
variable initial_pos equal ${pos}
variable depp equal -(v_pos-({initial_pos}))
compute forcez tool property/atom fz
compute f11 tool reduce sum c_forcez
variable loadz1 equal c_f11*1.603
dump 1 all custom 200 indent.xyz id type x y z
fix 4 tool move linear 0.0 0.0 0.5 units box
run ${load_step}
Thank you all for your help!
