Dear all
I have some water molecules in my system and I have defined a group with WATER name.
Also I have another molecules in the other groups.
The ID to define H-O-H angle is 2.
If I use:
fix 3 WATER shake 1e-6 1000000 0 a 1
What will happen?
I mean what is the result of using the wrong ID for angles in fix shake?
Thanks a lot for your time and attention,
Best Regards,
Nahid
Dear all
WATER name.
If I use:
What will happen?
lammps will (try to) do what you tell it to do, i.e. apply an angle
constraint to all angles of type 1 in the group WATER.
what do you expect? that lammps magically will not do what you asked
for but rather what you meant??
but angle 1 is not in group WATER.
So, I don’t know they constraint or not the angles of the other molecules are constraint.
how can i make sure?
thanks
Slay
So, I don't know they constraint or not the angles of the other molecules
are constraint.
please repeat after what i wrote in my previous e-mail:
apply an angle constraint to all angles of type 1 in the group WATER
that is a definite and clear statement. if there are no angles of type
1 in the group WATER there there are no contstraint angles. this is
elementary and straightforward logic.
why should there be a constraint anywhere else??
have you bothered to look at the logfile?
