a question in fix rigid
Hi all,
I am trying to simulate a Carbon Structure (CNT and/or Graphene) and my initial try is to use a rigid formulation. For that reason I used the following pair coeff command:
pair_coeff      * * lj/cut 0.086 3.4  0.0  # epsilon sigma cut-off radius
I am trying now to change the 0.0 (just to experiment with in a MD framework) with let's say 1.0 or something. From this time when I am trying to run a simulation I am getting NaN and Infs. Why is this happening? I know that it is caused due to the rigid but why it is affected ?
jim
Hi all,
what makes you think that this is cause by fix rigid?
from what you describe, i would suspect you have a
bad configuration. with a cutoff of 0 you have turned
off the interaction so you won't see any bad contacts,
but with a finite cutoff you do see them and they can
lead to NaNs and Infs.
It is just a guess. I don’t think it is a bad configuration since when I am using a non-rigid structure (bonds angles etc…) it works . i tried the same thing in a CNT created by VMD (to eliminate the possibility of the bad configuration) and still the same problem.
Jim
It is just a guess. I don't think it is a bad configuration since when I am
using a non-rigid structure (bonds angles etc...) it works . i tried the
what is "it" in this context?
you can still have bad contacts through bad choice
of the simulation box.
however, it is useless to speculate, when you can just show us.
please provide a simple input example that reproduces the problem,
but you believe it should work and the counter example w/o fix rigid
that does work. then it becomes a simple matter of comparing and
debugging instead of speculating and guessing.
thanks,
