I saw in the file neigh_gran.cpp, in the ´void
Neighbor::granular_bin_no_newton_ghost(NeighList *list)´ part, there
is
if (fix_history) {
if (rsq < radsum*radsum)
for (m = 0; m < npartner[i]; m++)
if (partner[i][m] == tag[j]) break;
if (m < npartner[i]) {
touchptr[n] = 1;
for (d = 0; d < dnum; d++) {
shearptr[nn++] = contacthistory[i][m*dnum+d];
? } else {
? touchptr[n] = 0;
? for (d = 0; d < dnum; d++) {
? shearptr[nn++] = 0.0;
} else {
touchptr[n] = 0;
My question is when ¨rsq < radsum*radsum¨ is met, then the two
particles should be seen as in touch with each other, right? They may
have already been registered as partners ( if (m < npartner[i]) ) , or
they have not been registered as partners yet (else). BUT touchptr in
both cases should be set to 1, right?
That´s why I have question about the codes starting with question mark
where rouchptr is set to 0. I don´t really understand it.
Another question is, I saw in many places of the code the variable
¨firstdouble¨, but I´ve never seen where this ¨firstdouble¨ variable
got its value. I often see that the ¨firstshear¨ variable gets the
value from firstdouble, okay. BUT where does firstdouble got his own
value??
Can someone help me a bit with these quesions?
Thank you so much~
