Dear lammps,
I am running lammps gpu ( 64 bit ) on two gtx cards. My computation contains LJ pair-wise
potential, FENE bond, and PPPM/gpu calculation.
When I input "package gpu force/neigh 0 0 -1", application run correctly.
When I input "package gpu force/neigh 0 0 -1" , it produce error
Setting up run ...
Cuda driver error 700 in call at file 'geryon/nvd_device.h' in line 41.
Dear lammps,
I am running lammps gpu \( 64 bit \) on two gtx cards\. My computation
correctly.
there is no difference between those two statements.
what do you do differently?
I have tried examps/gpu/in.melt, it worked for "package gpu force/neigh 0 0 1", but
failed for "package gpu force/neigh 1 1 1". This is error
- Using GPGPU acceleration for lj/cut:
- with 1 proc(s) per device.
Sorry,
it is a typo. My point is that lammps/gpu could
work under "package gpu force/neigh 0 0 -1"
fail under "package gpu force/neigh 1 1 -1"
It looks strange.
yangpeng
Sorry,
it works for me with the current lammps version.
there are two possible explanations.
1) you don't have an up-to-date lammps version
2) you have a broken GPU
Thanks.
I think maybe 2nd reason, because I compiled lammps using May 3 release tar.gz.
It worked yesterday, but produced errors today.
However, I could still find gpu information through "nv_get_devices", and "Nvidia-setting".
Best Regards,
Yangpeng
Thanks.
release tar.gz.
those will work for broken GPUs unless they are
completely nonfunctional.
the errors you show can come from memory corruption,
which can be caused from weak/broken memory or
overheating (quite possible with 2 GPUs). you should
run cuda memtest to make certain.
http://sourceforge.net/projects/cudagpumemtest/
Wow.
I will thanks Alex a lot. The 2nd card really have memory problem.
