About AIREBO and LJ potential
My model has 3 atom types,
Interaction: 1-1 AIREBO, 2-2 AIREBO, 1-2 LJ, 1*3 - 3 NONE.
This is my input:
pair_style hybrid airebo 3.0 1 0 lj/cut 10.0
pair_coeff * * airebo CH.airebo C NULL NULL
pair_coeff * * airebo CH.airebo NULL C NULL
pair_coeff 1 2 lj/cut 1 1
pair_coeff 1*3 3 none
And this is an error:
ERROR: All pair coeffs are not set (…/pair.cpp:229)
Anyone has suggestion?
This is my input:
pair_style hybrid
The second line overrides the first so your 1-1 interactions are effectively nullified by “NULL”. You need only one line with “C C NULL” and the next line “1 2 lj/cut 11” defines the 1-2 interactions.
Ray
ERROR: All pair coeffs are not set (../pair.cpp:229)
If the input is:
pair_coeff * * airebo CH.airebo C C NULL
  1. It looks like interaction 1-2 are AIREBO at the second line and LJ at the third line.
  2. With or without the third line, the input could be done, so it does not make sense.
Please read the entire pair_style hybrid doc page: http://lammps.sandia.gov/doc/pair_hybrid.html, after which you will see the full sense of these 4 lines.
Ray
