Dear All,
A long time ago I did a MD simulation of polyethylene using airebo potential, and I encountered some problems. Then you reminded me to remove all definitions of bonds, angles, and dihedrals from the data file, as shown in below message. The simulation was indeed ok after I removed relative definitions. However, I can not understand why should I remove the definitions. Is it substantial requirement by the airebo potential? Most importantly, how will the bond, angle, and dihedral behaviors be described if removing their definitions from data file? I guess you should have answers to my above questions! Your comments will be highly appreciated!
Yusong He
