I use “fix rigid” with “torque * off off off”.
With old version Lammps_10Aug15, it works well.
With new version Lammps_08Jun16, rigid group was rotated after about 400000 timesteps.
I used the same code with both versions.
Could you check again with new version?
I use "fix rigid" with "torque * off off off".
timesteps.
there have been only whitespace and similar changes w/o change to
functionality to src/RIGID/fix_rigid.cpp during that period. so in all
likelihood, the effect you are describing has to have a different
reason.
if you disagree, please provide a simple, small and fast to run test
example to back up your claim.
