I want to combine the tersoff potential of AlN and GaN, but I do not know the combination rules, can anyone tell me?
Many thanks
Xiaojing
Many thanks
Xiaojing
have you checked the original papers by tersoff describing the
potential functions?
If the N parameters are exactly the same for the AlN and GaN potentials, then you may try to come up with the Al-Ga cross terms. First use the mixing rule to determine bigA, bigB, lambda and alpha. Then set the symmetry term m to 1, angular terms c and h to 0 and d to 1. Last define a proper cutoff that cuts between 1NN and 2NN of Al-Ga.
There, now you have a first hack at the Al-Ga-N Tersoff potential, but this only works if you have the same N.
Ray
