I wish to use a SW potential for a simulation involving a Mg-Al-Si-O system. For this I have created a *.sw file with 64 permutations of the previously mentioned atoms (below the 64 permutations are listed). I have a couple of questions that arose from trying to use my *.sw file in lammps: I get the following error message:
“Reading potential file MgAlSiO.sw with DATE: 01.10.2018
ERROR: Potential file is missing an entry (…/pair_sw.cpp:501)
Last command: pair_coeff * * MgAlSiO.sw Mg Al Al Si Si Si O O O O O O”
Now each line of parameters contains 11 numerical parameters (as required according to the description of the pair_style sw), along with the three atom names. So I assume this error does not come from there. I suppose it comes from the number of permutations required to exist in the *.sw file. Now I wonder:
How does lammps know the number of permutations that must exist in the *.sw file? In my model I wish to use 12 different atom types; but only four different elements (namely Mg, Al, Si, and O). Is it due to the number of different elements named in the command: “pair_coeff * * MgAlSiO.sw Mg Al Al Si Si Si O O O O O O”? If that is the case: why 64 permutations would not be the necessary number of entries?
Is there any special rule that applies to the formatting of the *.sw file? I use single space to separate all the different values in each line. For example: “O Al Al 1.0 1.0 2.6 6.2400 2.0 -0.333313 0.0 0.0 0.0 0.0 0.0”. Could the error come from this? If it does, what would be a good way to format the *.sw file?
Thanks a lot for your help.
Sincerely,
