About the variable accuracy in the if-run case
Hello everyone:
I performed a run with the maximal kinetic energy of atoms in the system as the termination condition. When the maximum was lower than 1.0, the nve simulation was terminated and the next nvt simulation started. So I wrote the input script as following:
fix 3 all nve
run 1000
label loop
compute m all reduce max c_4
variable k equal c_m
run 200
if “$k <1.0” then “jump inp break”
print “max ke/atom: $k”
jump inp loop
label break
variable k delete
unfix 3
fix 4 all nvt temp 300 300 0.01 drag 0.2
However, the simulation stopped in the “if-then” statement with the error message: Compute used in variable between runs is not current. I read a lot about the variable accuracy part in the variable doc but I still cannot find a solution to this problem. Could you please help me? Thank you very much.
2011-12-15
Hello everyone:
fix 3 all nve
run 1000
label loop
run 200
jump inp loop
label break
variable k delete
unfix 3
