Hi all,
I am trying to access the force resulting purely from deformation applied through “fix deform” command, while integrating via NVE. Using the “fix store/force” or “fix store/state” won’t work here, since fix deform does not store any per-atom forces, unlike constraints like “fix indent” which affect forces directly. I have checked this by issuing fix store/force after “fix nve” and “fix deform”, which return the same per-atom force at a time step.
Is there another way to store these forces? I would like to eventually compute the work done by the deformation force.
Thanks in advance,
Raghavan
