I am trying to access per atom voronoi volume for use in a pair potential by retrieving data from compute voronoi/atom. I realize this process is similar to that used in computeHeatFlux to retreive vector_atom and array_atom quantities so I borrowed some inspiration from it…but my bit of code doesn’t compile (specifically the command involving compute_peratom()). I get an error which states ’ error: invalid use of incomplete type ‘class LAMMPS_NS::Compute’’
int vorocompute = modify ->find_compute(char_vorocomputestring_array);
Compute *c_vorocompute;
c_vorocompute=modify->compute[vorocompute];
memory->create(voro_array,nmax,2,"pair:voro_array");
c_vorocompute->compute_peratom();
voro_array=c_vorocompute->array_atom;
I’ve used a similar procedure to get data from fix_store so I thought this would work…
Any help is much appreciated!
Best
