I did three simple tests( but I’m not sure if it is good enough to explain
what problem I have):
1)input the command:
fix 3 water addforce 0.0 0.0 -v_force region forcing
2)delete the command like this:
#fix 3 water addforce 0.0 0.0 -v_force region forcing.The output energy,temperature,pressure,volume and even the coordinate of
atoms were totally the same. I think ‘-v_force’ seems not work. But if I
yes. it cannot work.
nothing in the the documentation says that you
can use an expression instead of a variable or number.
you have to define the force variable to be the
negative of what it currently is.
PEBCAC,
I see. I am really so sorry. I read the document again and again but even didn’t realize that. Thanks so… much.
I want to add a force which is computed from a specified constant pressure just like what I wrote in the input file. In ‘real’ unit, I’m not sure if I need to transfer the pressure unit from ‘atm’ to ‘kcal/(AAA)’?
I really appreciate your help.
Hang
