addforce using sphere diameter
Sorry for disturbing you, I have spheres with random diameters and I want to add force to spherical particles using fix addfocre which includes diameter of each sphere, but i got error, please let me know where I’m wrong?
atom_style sphere
variable Diam atom random(0.024,0.026,16)
set region mybox diameter v_Diam
variable dz atom 2diameter # or 2v_diameter
fix archimeius all addforce 0.0 v_dz 0.0
ERROR: Invalid thermo keyword in variable formula (…/variable.cpp:1716)
but when I use position of particles instead of diameters , it works.
Thanks in Advance,
The invalid keyword is diameter. The only keywords allowed
are in the thermo_style command, not from dump commands.
If you want an atom-style variable that uses diameter or radius,
you need to use compute property/atom, then reference
the compute in your per-atom varaible formula.
of each sphere, but i got error, please let me know where I'm wrong?
atom_style sphere
variable dz atom 2*diameter # or 2*v_diameter
ERROR: Invalid thermo keyword in variable formula (../variable.cpp:1716)
because those are supported parameters, diameter is not. it is nowhere
listed as supported. to get access to the diameter property, you need
to define a suitable compute property/atom and reference that instead.
Thank you very much.
