Adding USER-COLVARS package
Dear LAMMPS Users
I have tried to follow the instructions on http://lammps.sandia.gov/doc/Section_packages.html to add USER-COLVARS package.
However, when I am in src direction and do:
make lib-colvars args="-m mpi"
I have encountered the following error:
Installing lib colvars
Building libcolvars.a …
File “Install.py”, line 135, in
print(subprocess.check_output(cmd, shell=True).decode(‘UTF-8’))
AttributeError: ‘module’ object has no attribute ‘check_output’
I am not very familiar with adding packages that requires extra libraries, and I would be grateful for any help.
Best Wishes
Lunna
Dear LAMMPS Users
package.
Building libcolvars.a ...
  File "Install.py", line 135, in <module>
    print(subprocess.check_output(cmd, shell=True).decode('UTF-8'))
AttributeError: 'module' object has no attribute 'check_output'
this has nothing to do with building, this is an error stemming from
you having a rather old python.
this python script is included for convenience, but you can find in
the documentation instructions for how to compile the library directly
without the Install.py script.
Dear Axel
Thanks very much for your advice. I have installed the package successfully.
Best Wishes
Lunna
