Adding Velocities From Python via fix python/invoke
Hi All,
I am trying to write a python script which runs LAMMPS as a library with python/lammps interface
from lammps import lammps
During the simulation lets say every 100 steps, I would like to add Velocities to some atoms in the system just before the verlet step.
I am trying to simulate electron scattering and momentum transfer to atoms.
I am using
fix pf  all python/invoke 50 post_force post_force_callback
So this fix will call a function in my python script and I can manipulate forces or velocities of the atom.
So my question is should I just update velocities at this step or should I update forces to add the momentum via
Delta P = Delta F * timestep
dundar.
Dundar Yilmaz, Ph. D.
Associate Research Professor
Department of Mechanical and Nuclear Engineering
138 Research East Building
Penn State University
University Park, PA 16802
For post_force you should increment the forces.
The Verlet integration within LAMMPS will use
those forces to increment velocities.
