Dear LAMMPS community,
I am hoping to get some advice. I am currently trying to build and tune LLAMPS on an HPC system that uses Fujitsu’s A64FX chip. The main goal here to build with Scalable Vector Extension (SVE) support to take advantage of this CPU architecture.
So far, I’ve successfully built LLAMPS with GCC 11, ARM compilers version 21, and the Fujitsu Compilers (combined with OpenMPI 4.1.1) with the appropriate flags for SVE support.
The resulting lmp_mpi binary runs successfully, but it appears that nothing has been vectorized.
Does anyone know if LLAMPS supports SVE? And if so, could anyone provide some advice on how to get this working?
Here is an example build script (in this case with ARM + OpenMPI):
#!/usr/bin/env bash
CC=mpicc
CXX=mpic++
FC=mpif90
export CFLAGS="-O3 -mcpu=a64fx -armpl"
export CXXFLAGS="${CFLAGS}"
export FCFLAGS="${CFLAGS}"
export FFLAGS="${CFLAGS}"
module load cmake ffmpeg arm-modules/21.1 openmpi/arm21/4.1.1 libpng/gcc/1.6.37
source /lustre/software/kim-api/2.2.1/bin/kim-api-activate
cmake -DCMAKE_INSTALL_PREFIX:PATH=/lustre/software/lammps/arm21/29Sep2021 \
-D BUILD_SHARED_LIBS=on -D PKG_KIM=on -D DOWNLOAD_KIM=no -D PKG_MANYBODY=yes -D PKG_MOLECULE=yes \
-D PKG_RIGID=yes -D BUILD_MPI=yes BUILD_OMP=yes PKG_USER-OMP=yes -D PKG_OPT=yes -D PKG_PYTHON=yes \
-D PKG_COLLOID=yes -D PKG_COMPRESS=yes -D PKG_CORESHELL=yes -D PKG_DIPOLE=yes -D PKG_GRANULAR=yes \
-D PKG_KSPACE=yes -D PKG_POEMS=yes -D PKG_REPLICA=yes -D PKG_PERI=on -D PKG_DRUDE=on -D PKG_BODY=on \
-D PKG_SHOCK=yes -D PKG_SRD=yes -D LAMMPS_MACHINE=mpi -D PKG_REAXFF=on -D PKG_MISC=on \
-D CMAKE_CXX_COMPILER=${CXX} -D CMAKE_C_COMPILER=${CC} -D CMAKE_Fortran_COMPILER=${FC} \
-D CMAKE_CXX_FLAGS="${CXXFLAGS}" -D CMAKE_C_FLAGS="${CFLAGS}" -D CMAKE_Fortran_FLAGS="${FFLAGS}" ../cmake
Any advice is most welcome.
Thanks!
Dave
