If you want to use airebo in anything other than metal units, you’ll have to convert the parameters. But note that the epsilons are not the only parameters with energy units, so you’ll have to be very careful.
It’s usually much easier to simply use metal units, and convert any numbers LAMMPS gives in post processing.
Kristof
