Airebo potential
Dear Lammps Users,
I am trying to run MD for one SWNCT(10,10). I have never used aired potentials before but I followed the manual but I end with the following error Incorrect args for pair coefficients (…/pair_airebo.cpp:161). I checked the pair coefficients and every thing looks fine. Here is a copy of the input file. I did not include all the file because the simulation stop at pair coefficient
boundary f f f
#processors 5 4 6
atom_style molecular
newton on
read_data tube1.txt
pair_style airebo 1.7 1 1
pair_coeff * * CH.airebo C C
dump 1 all custom 5000 tube.lammpstrj id mol type x y z c_1 c_2
c_3
Also here is copy of the text file tube1.txt
LAMMPS data file. CGCMM style. atom_style molecular generated by VMD/TopoTools v1.7 on Wed Sep 13 00:16:58 EDT 2017
1640 atoms
2440 bonds
4840 angles
1 atom types
1 bond types
1 angle types
-50.000000 50.000000 xlo xhi
-50.000000 50.000000 ylo yhi
-0.614012 100.083956 zlo zhi
Pair Coeffs
Hi Elene,
You have only 1 atom type in the structure and yet you defined two atom types in the pair_coeff command, hence the error.
Ray
