Good morning to all,
I have a quick question regarding a stockmayer system with aligned dipoles, any help will be appreciated.
I need to simulate a system of dipolar lennard jones particles with aligned dipoles, i.e. the dipoles don't rotate, are always aligned in the z direction. Is there any other way to do this, to disable the rortation of dipoles?
the second question: the dipolar torques will be calculated every timestep which is not needed as they are not rotating, is there a way to disable the calculation of the torqes in both r and k space for the dipolar forces.
Thanks a lot for your time
Manuel Valera
If you don’t integrate the dipoles, they won’t change
orientation. E.g. just use fix nve on the dipolar particles
instead of fix nve/sphere dipole.
2nd Q: if you don’t want to compute the torques at all,
it’s not clear to me why you are defining dipoles in
the first place.
Thanks a lot for your reply.
Thanks, this should work.
the first place.
In the system we are simulating, colloids are immerse in an external electric field along the z axis, the induced dipoles on the particles will never rotate, therefore there is no need to calculate torques. The effective potential would be:
u(rij) ~ 1/rij^3*(1-cos(theta)^2)
where theta is the angle between the z axis and the vector from particle i to j (rij). I could implement this potential in lammps and use it as a pair potential with a cut and I will not have to use dipoles if I go this route. However I was hoping to be able to use a k-solver to take care of long range nature of 1/r^3, but I believe ( and correct me if I am wrong) there is not k-solver for dipoles implemented in lammps yet?
Thanks again for your time
Manuel
yes, there is no long-range dipole solver yet -
we have a prototype of one that uses Ewald,
but it has not yet been fully debugged.
