All pair coeffs are not set
Dear Lammps Users,
I am simulating the system including metal (Ag) and organic. Interaction between Ag and organic atoms is LJ potential. For Ag, the potential is EAM. It includes 6 atom styles and the LJ parameters are in data file. However, it shows error “All pair coeffs are not set”.
Here is the input script.
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style charmm
pair_style hybrid lj/cut/coul/cut 10.0 8.0 eam
neighbor 2.0 bin
special_bonds amber
read_data 2016712organic_Ag.data
pair_modify pair lj/cut/coul/cut mix arithmetic
pair_coeff 6 6 eam Ag_u3.eam
Here is LJ parameter in the data file:
Pair Coeffs
1 lj/cut/coul/cut 0.01084085 4 # S
2 lj/cut/coul/cut 0.003729252 3.816 # C1
3 lj/cut/coul/cut 0.000650451 2.918 # H
4 lj/cut/coul/cut 0.003729252 3.816 # C2
5 lj/cut/coul/cut 0.003729252 3.816 # C3
6 lj/cut/coul/cut 0.001561082 2.805 # Ag
Could some users give me some suggestions? Thank you very much!
Dear Lammps Users,
it shows error "All pair coeffs are not set".
this is expected, since your "pair_coeff 6 6..." statement will
overwrite the corresponding entry in the data file and then LAMMPS
cannot determine all mixed terms between atom type 6 and the others.
atom_style full
bond_style harmonic
neighbor 2.0 bin
special_bonds amber
Pair Coeffs
specify all coefficients, including the mixed terms as pair_coeff statements.
you probably also want to change from lj/cut/coul/cut to
lj/cut/coul/long, or at the very least make your coulomb cutoff
longer, since with 8 angstrom, you will have serious errors due to
truncation of the coulomb potential.
Dear Axel,
Thanks for your reply. How should I modify the input script or data file to exclude the 6 6 type interaction for lj/cut/coul/cut and just consider 6 6 for eam? I try to modify it as below.
Put 1~5 pair coefficients in data file. And 1 6, 2 6, 3 6, 4 6, 5 6, and 6 6 pair coefficients are in input script.
Input script:
pair_style hybrid lj/cut/coul/cut 10.0 8.0 lj/cut/coul/cut 10.0 8.0 lj/cut/coul/cut 10.0 8.0 lj/cut/coul/cut 10.0 8.0 lj/cut/coul/cut 10.0 8.0 lj/cut/coul/cut 10.0 8.0 eam
pair_modify pair lj/cut/coul/cut 1 mix arithmetic
pair_coeff 1 6 lj/cut/coul/cut 2 0.010952671 3.4025
pair_coeff 2 6 lj/cut/coul/cut 3 0.004042809 3.3105
pair_coeff 3 6 lj/cut/coul/cut 4 0.001691173 2.8615
pair_coeff 4 6 lj/cut/coul/cut 5 0.004042809 3.3105
pair_coeff 5 6 lj/cut/coul/cut 6 0.004042809 3.3105
Data file:
Pair Coeffs
1 lj/cut/coul/cut 1 0.01084085 4 # S
2 lj/cut/coul/cut 1 0.003729252 3.816 # C1
3 lj/cut/coul/cut 1 0.000650451 2.918 # H
4 lj/cut/coul/cut 1 0.003729252 3.816 # C2
5 lj/cut/coul/cut 1 0.003729252 3.816 # C3
But it shows “ERROR: Unexpected end of PairCoeffs section (…/read_data.cpp:1601)”
Dear Axel,
I already made a suggestion.
Dear Axel,
Thanks. I know you said that “pair_coeff 6 6…” statement will overwrite the corresponding entry in the data file and then LAMMPS cannot determine all mixed terms between atom type 6 and the others.
I follow your suggestion to try to modify it. But it seems a new error appears. Is my modification incorrect?
Dear Axel,
Thanks. I know you said that "pair_coeff 6 6..." statement will overwrite
you didn't read my entire reply.
yes. very obviously.
