Ambiguous Run Type
Counter over unique run types returns:
‘GGA’: 89083, ‘GGA+U’: 32274, ‘None or LDA’: 2333, ‘None or LDA+rVV10’: 571, ‘None or LDA+U’: 254.
While LDA is perfectly reasonable, the 'None or ’ prefix is rather obscure, what is it supposed to mean?
Hi @Lsky,
This is a bug in the database. There was likely an issue with one of the calculation parsing routines that didn’t recognize a parameter as valid. We think we’ve found the source of the bug and have prioritized it for the next DB release.
Hi @shyamd,
In the meantime, should those be treated as ‘LDA’, ‘LDA+rVV10’, 'LDA+U respectively, or there is a possibility for them being mixed with each other?
Hi @Lsky,
They should be none of those. They should be either GGA+U if there is oxygen or fluorine in the composition. Otherwise they are GGA.
