Hello
I utilize colvars module in LAMMPS to calculate PMFs. Use Lammps version 2015-07-21. In this process, I use umbrella sampling method.
My colvars configuration file is:
colvar {
name d
lowerBoundary 15.0
upperBoundary 250.0
distanceZ {
componentCoeff -1
main {
atomNumbersRange 109927-110830 #MOF235
ref { dummyAtom (72.261715, 80.200976, 88)
distanceZ {
componentCoeff 1
main {
atomNumbersRange 7-9 #CH3CN
harmonic {
name distance
colvars d
forceConstant 100.0
centers 41.51533 # go from 41.51533 A…
targetCenters 135.11534 # … to 135.11534 A
targetNumSteps 5000000 # with these many time steps
outputCenters on
colvarsTrajFrequency 1000
colvarsRestartFrequency 1000
analysis true
and my lammps input file is:
units real
atom_style full
boundary p p f
pair_style lj/cut/coul/long 12.0
pair_modify shift yes mix arithmetic
bond_style harmonic
angle_style harmonic
kspace_style pppm 1.0e-4
kspace_modify slab 3.0
read_data SMD.data
neighbor 2.0 bin
timestep 1.0
#special_bonds lj/coul 0.0 0.0 0.5
group C2H3N type 1 2 3
group MOF type 4 5 6 7 8 9 10 11 12 13
group FeCl4 type 14 15
neigh_modify exclude group MOF MOF check no
neigh_modify exclude group FeCl4 MOF check no
neigh_modify exclude group FeCl4 FeCl4 check no
neigh_modify exclude group FeCl4 C2H3N check no
velocity C2H3N create 300 4928459
fix 1 FeCl4 setforce 0.0 0.0 0.0
fix 2 all nvt temp 300 300 100.0
#fix 3 C2H3N wall/reflect zlo 75 zhi EDGE units box
fix 4 MOF rigid group 1 MOF force * off off on torque * off off off
#fix 5 MOF setforce 0.0 0.0 NULL
fix 6 all colvars mof235.colvars
compute x MOF com
dump 1 all atom 1000 SMD1.atom
dump_modify 1 scale no
dump_modify 1 sort 1
thermo_style custom step cpu temp press etotal pe vol f_6 c_x[1] c_x[2] c_x[3]
thermo_modify flush yes
thermo 1000
run 1000000
run 1500000
fix 6 all colvars mof235.colvars input out.colvars.state output out2
run 2500000
I want to pull a cluster from a vacuum into solvents for calculate the PMF. But I always got a error:
Error: keyword “ ” is not supported, or not recognized in this context.
Error: in setting up component “distanceZ”.
Could you tell me how to solve this error?
Thanks!
