angular keyword of fix momentum issue
It seems that the “angular keyword” of the “fix momentum” does not work properly in the latest 64-bit Windows version (31/10/2016) of the software. In the previous versions, it worked without any issue but in the latest version, including or excluding the angular keyword results in the same outputs in my simulations, i.e., the angular momentum is never zeroed and the entire structure rotates.
Ali
It seems that the "angular keyword" of the "fix momentum" does not work
which is the latest previous version where it worked for you?
please provide a small input example that can be used for testing,
i.e. that takes very little time to run and yet reproduces the issue.
thanks,
