angular keyword of fix momentum issue
Thanks for your reply. Did you exactly execute the input file with the latest version (31/10/2016)? The previous version that I have installed, works properly. I ran some small structures such as CNTs and graphene layers, as you did, and my outputs for angular momentums are even smaller than your results (e-14) with the previous version. However, the latest one gives angular momentums of the order e+4 with the same input file. I think the problem is with the latest 64-bit windows executable version, which I have downloaded from here http://rpm.lammps.org/windows/64bit/lammps-64bit-latest.exe
i am using linux and i am using the current development version.
there is a new set of windows installers now available for download.
this is based on the latest development snapshot. it should have the
same behavior as the linux version i tested.
please give it a try and let us know, if that solves your problems.
thanks,
