Hi all,
Is there a way to apply a fix after some initial run - just to make sure the fix is applied after system equilibrium is reached? Something along the line of:
Run until equilibrium
run ${nrun}
Apply the middle fix
fix some_fix groupiD ${vars}
Run post equilibrium
run ${nrun}
I tried using the syntax above, but the fix ended up being applied during the equilibrium run, not after it. Do I have to rely on restart/rerun or other forms of read/write data to achieve this?
Many thanks,
Quang
Hi all,
of:
# Run until equilibrium
run ${nrun}
# Apply the middle fix
# Run post equilibrium
run ${nrun}
that makes no sense. what you have above is *exactly* how it should work.
you have to watch your output carefully. you can also use the "info"
command to print out a list of currently defined fixes. you have to
make certain, that your "some_fix" is not already defined and that you
are looking at the correct run commands.
I figured out the problems (more like my problem but I feel it could be worth sharing): I put the dump command between these run, which mess up my output…
Thanks, Axel.
QT
