A 1.0 fs timestep should be suitable for the kind of system you have.
The 18K is only one concern, but rather the gigantic pressure is very worrisome too.
Something is gravely wrong with your system from the very beginning.
You said that you have started from a simulation that was equilibrated with fix npt.
It looks like something went wrong there already or when creating the data file.
This is not something that can be easily fixed from remote.
As a point of reference, here is a simple input deck for a tiny system demonstrating that this kind of simulation should be working fine with a 1 fs timestep and will produce proper temperature and pressure.
The molecule file, H2O.txt, is taken from the examples/mc/ folder of the LAMMPS source distribution.
units real
atom_style full
atom_modify map array
region box block -5 5 -5 5 -5 5
create_box 4 box bond/types 1 angle/types 1 &
extra/bond/per/atom 2 extra/angle/per/atom 1 extra/special/per/atom 2
mass 1 15.9994
mass 2 1.008
mass 3 22.989769
mass 4 35.453
pair_style lj/cut/coul/long 10.0
pair_coeff 1 1 0.1553 3.166
pair_coeff 2 2 0.0 1.0
pair_coeff 3 3 0.3526418 2.1595384928
pair_coeff 4 4 0.0127850 4.8304528498
kspace_style pppm 0.00001
bond_style harmonic
bond_coeff * 1000.0 1.0
angle_style harmonic
angle_coeff * 100.0 109.47
molecule water H2O.txt
# fill the box with randomly placed water molecules w/o overlap
create_atoms 0 random 32 34564 NULL mol water 25367 overlap 1.33
create_atoms 3 random 2 42343 NULL overlap 1.33
create_atoms 4 random 2 42343 NULL overlap 1.33
set type 1 charge -0.8476
set type 2 charge 0.4238
set type 3 charge 1.0
set type 4 charge -1.0
velocity all create 300.0 5463576
timestep 1.0
minimize 0.0 0.0 1000 10000
reset_timestep 0
# since the trajectory and forces are kept identical through fix alchemy,
# we can do fix npt simulations, but we must use the "mixed" pressure
fix integrate all nvt temp 300 300 1.0
fix rigid all rattle 0.001 10 10000 b 1 a 1
thermo_style custom step temp press etotal density pe ke
thermo 1000
run 20000
And the corresponding output:
Created orthogonal box = (-5 -5 -5) to (5 5 5)
1 by 2 by 2 MPI processor grid
Read molecule template water:
1 molecules
0 fragments
3 atoms with max type 2
2 bonds with max type 1
1 angles with max type 1
0 dihedrals with max type 0
0 impropers with max type 0
Created 96 atoms
using lattice units in orthogonal box = (-5 -5 -5) to (5 5 5)
create_atoms CPU = 0.006 seconds
Created 2 atoms
create_atoms CPU = 0.000 seconds
Created 2 atoms
Setting atom values ...
32 settings made for charge
64 settings made for charge
PPPM initialization ...
using 12-bit tables for long-range coulomb (src/kspace.cpp:342)
G vector (1/distance) = 0.31510913
grid = 10 10 10
stencil order = 5
estimated absolute RMS force accuracy = 0.0017608851
estimated relative force accuracy = 5.3028531e-06
using double precision KISS FFT
3d grid and FFT values/proc = 2448 300
Generated 6 of 6 mixed pair_coeff terms from geometric mixing rule
Neighbor list info ...
update: every = 1 steps, delay = 0 steps, check = yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 2 2 2
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut/coul/long, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/3d
bin: standard
Setting up cg style minimization ...
Unit style : real
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 8.282 | 8.285 | 8.287 Mbytes
Step Temp E_pair E_mol TotEng Press
0 300 16090.637 3.7051245e-05 16179.167 4512151.3
422 300 -840.19853 13.578801 -738.08967 297.17441
Loop time of 0.383567 on 4 procs for 422 steps with 100 atoms
98.6% CPU use with 4 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = linesearch alpha is zero
Energy initial, next-to-last, final =
16090.6370375965 -826.619728010597 -826.619728010597
Force two-norm initial, final = 157158.94 0.90721236
Force max component initial, final = 102725.86 0.42986695
Final line search alpha, max atom move = 1.2719297e-08 5.4676055e-09
Iterations, force evaluations = 422 871
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.11493 | 0.19045 | 0.2644 | 12.2 | 49.65
Bond | 0.00086148 | 0.00091512 | 0.0010015 | 0.0 | 0.24
Kspace | 0.075517 | 0.14949 | 0.22512 | 13.8 | 38.97
Neigh | 0.0019501 | 0.0019727 | 0.0019948 | 0.0 | 0.51
Comm | 0.034833 | 0.035112 | 0.035401 | 0.1 | 9.15
Output | 0 | 0 | 0 | 0.0 | 0.00
Modify | 0 | 0 | 0 | 0.0 | 0.00
Other | | 0.005624 | | | 1.47
Nlocal: 25 ave 30 max 23 min
Histogram: 2 1 0 0 0 0 0 0 0 1
Nghost: 2825.5 ave 2872 max 2786 min
Histogram: 1 1 0 0 0 0 1 0 0 1
Neighs: 9053.5 ave 11609 max 5796 min
Histogram: 1 0 0 1 0 0 0 0 0 2
Total # of neighbors = 36214
Ave neighs/atom = 362.14
Ave special neighs/atom = 1.92
Neighbor list builds = 6
Dangerous builds = 0
Finding RATTLE clusters ...
0 = # of size 2 clusters
0 = # of size 3 clusters
0 = # of size 4 clusters
32 = # of frozen angles
find clusters CPU = 0.000 seconds
grid = 10 10 10
stencil order = 5
Setting up Verlet run ...
Unit style : real
Current step : 0
Time step : 1
RATTLE stats (type/ave/delta/count) on step 0
Bond: 1 1.01151 0.013248 64
Angle: 1 107.417 3.36471 32
Per MPI rank memory allocation (min/avg/max) = 8.407 | 8.41 | 8.412 Mbytes
Step Temp Press TotEng Density PotEng KinEng
0 314.31925 -1639.9431 -777.42449 1.1513817 -840.19853 62.774041
1000 301.06544 5267.2754 -677.99582 1.1513817 -738.12289 60.127065
2000 336.37293 -1012.8962 -700.49593 1.1513817 -767.6744 67.178475
3000 286.79017 -1409.7737 -692.29576 1.1513817 -749.57185 57.276091
4000 315.46207 3156.1877 -698.07058 1.1513817 -761.07286 63.002278
5000 292.66803 -614.08452 -697.48419 1.1513817 -755.93417 58.449982
6000 309.44319 -1149.598 -686.7636 1.1513817 -748.56383 61.800222
7000 254.05414 1614.5969 -689.78701 1.1513817 -740.52525 50.738237
8000 310.27637 -4042.8915 -680.18928 1.1513817 -742.15589 61.966619
9000 286.39329 -5025.28 -704.61555 1.1513817 -761.81238 57.196827
RATTLE stats (type/ave/delta/count) on step 10000
Bond: 1 0.999997 2.24538e-05 64
Angle: 1 109.47 0.00193684 32
10000 296.24172 -3953.4996 -697.67943 1.1513817 -756.84313 59.1637
11000 323.56059 -1115.9031 -690.46975 1.1513817 -755.08941 64.619668
12000 284.75731 3496.3049 -694.99612 1.1513817 -751.86622 56.870098
13000 262.9934 1931.4308 -699.40834 1.1513817 -751.93187 52.523535
14000 274.22344 -1159.0547 -712.0239 1.1513817 -766.79023 54.766335
15000 342.64355 111.45531 -701.31229 1.1513817 -769.7431 68.430807
16000 334.10769 -2714.1437 -690.65991 1.1513817 -757.38599 66.726074
17000 321.14279 1544.3886 -692.46087 1.1513817 -756.59766 64.136799
18000 275.20771 -3544.9569 -708.25972 1.1513817 -763.22263 54.962907
19000 347.23547 -1441.2803 -677.07697 1.1513817 -746.42485 69.34788
RATTLE stats (type/ave/delta/count) on step 20000
Bond: 1 0.999989 5.30216e-05 64
Angle: 1 109.47 0.00690826 32
20000 261.91935 800.4894 -686.0143 1.1513817 -738.32333 52.309032
Loop time of 7.45233 on 4 procs for 20000 steps with 100 atoms
Performance: 231.874 ns/day, 0.104 hours/ns, 2683.725 timesteps/s, 268.373 katom-step/s
98.5% CPU use with 4 MPI tasks x 1 OpenMP threads
Pair | 2.0428 | 2.8866 | 3.5676 | 32.4 | 38.73
Bond | 0.0028994 | 0.0031749 | 0.0038875 | 0.7 | 0.04
Kspace | 1.7449 | 2.4415 | 3.2911 | 35.7 | 32.76
Neigh | 0.1326 | 0.13281 | 0.13304 | 0.1 | 1.78
Comm | 0.83983 | 0.84494 | 0.85833 | 0.8 | 11.34
Output | 0.00046679 | 0.00049966 | 0.00057587 | 0.0 | 0.01
Modify | 1.0706 | 1.0743 | 1.0795 | 0.3 | 14.42
Other | | 0.06855 | | | 0.92
Nlocal: 25 ave 28 max 22 min
Histogram: 1 0 0 1 0 0 1 0 0 1
Nghost: 2898.25 ave 2944 max 2847 min
Histogram: 1 0 0 1 0 0 0 0 1 1
Neighs: 9061.5 ave 11597 max 5198 min
Histogram: 1 0 0 0 0 0 1 1 0 1
Total # of neighbors = 36246
Ave neighs/atom = 362.46
Neighbor list builds = 469
Total wall time: 0:00:07
