ATC example for bar across a gap
Dear Lammps users,
I want to create a simple test input (say fcc with LJ potential from the bar example) that is embedded in a finite element region with a two temperature model.
I want the md region to be a bar with vacuum above and below it (in the z direction), then either side of it I want a finite element region that covers the full distance in z (no vacuum), so the md region is fully enclosed by material. Similar to the set up for from the carbon nano-tube simulation.
I will eventually want to put a laser pulse into the bar. Is this possible?
Anthony
...and another one.
If your question is it possible to have a vacuum region in addition to a solid/LJ region the answer is yes.
I'll look for some representative input files and send them to you.
Reese
Reese Jones
[email protected]
925 294-4744
Dear Reese,
To clarify I want the following geometry where
m = md region containing atoms at t=0
f = finite element region
p = periodic boundary condition
b = non-periodic boundary
pbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbp
pffffffffff ffffffffffp
pffffffffffmmmmmmmmmmmmmmmmffffffffffp
where the gap will be treated with MD and is initially empty and z is up the page.
Anthony
