I’ve just downloaded the master branch of LAMMPS using git. I’m reading “examples/USER/atc/README”. The file mentions
‘temp.init - Initial set of atomic positions and velocities’
as one of the input files for the ‘thermal’ and ‘two_temperature’ examples. But there are no such files in the corresponding folders. So LAMMPS fails to run the “in.*” files that contain the command “read_data temp.init”.
Could you please point out the location of the files “temp.init”? I would like to reproduce several AtC examples.
?? hardy/nvt.data should be renamed to ‘nvt.init’ ??
Jeremy, Reese, could you please find those input files? The *.screen files in the example folders show that the examples were successfully run some time ago.
could you please clarify why the following examples do not work?
(examples/USER/atc/drift_diffusion/)
ddm_schrodinger
finite_well
poisson2d_noatoms
schrodinger-poisson2d_Jconstraint
schrodinger-poisson2d_convective
schrodinger-poisson2d_noatoms
I would like to use schrodinger_poisson_solver in particular.
What are the reasons that make some fix_modify command arguments invalid?
How complicated are the issues? Can it be possible for me to resolve them with little effort?
Jeremy, Reese, please give me some hints because it will take long to work something out having only the source code.
