atom recognition
Dear All
I am creating Au(111) hcp lattice surface using create atoms. Everything works well except the atom recognition in xyz file. It recognize as number 1 so when i converting output of this into lammps data using topo in vmd its giving the mass as mass of the hydrogen. I need to combine this surface with SAM monolayers and do the simulation.
Did I missed something?
Here is the input script
atom_style full
lattice hcp 2.916 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block 0 7 0 4 0 3
create_box 1 box
create_atoms 1 box
set group all type 1
set type 1 charge 0.0
neighbor 2.0 multi
pair_style eam
pair_coeff 1 1 Au_u3.eam
print ======================================================================
print “500 steps CG Minimization.”
dump 1 all atom 25 {sname}_min.lammpstrj dump_modify 1 image yes scale yes dump 2 all xyz 5000 min_{sname}.xyz
min_style sd
minimize 1.0e-4 1.0e-6 500 50000
min_style cg
undump 1
undump 2
Thanking you in advance
Mathi
Dear All
yes. how can VMD know that a "1" means an Au atom?
it would be better you write a restart, use restart2data and
input the data file. or you can use VMD scripting to override
all the settings that you want to the properties that you need.
Recently I got the same problem when I tried to view lammps xyz files with Jmol applet.
So I added “dump_modify element” option for dump xyz style. It associates element names with atom types like for cfg and image dump styles in the current lammps version.
I think this modification will be useful in your case.
Try the following to use it:
  1. Replace dump_xyz.cpp and dump_xyz.h files in lammps src directory and recompile lammps
  2. Add “dump_modify 2 element Au” after "dump 2… " line
Grigory Smirnov
2012/4/10 Vasumathi V <vasuphy@…24…>
dump_xyz.h (1.5 KB)
dump_xyz.cpp (3.98 KB)
grigory,
do you mind, if i integrate this into LAMMPS-ICMS and
then, when fully tested, send to steve for inclusion into
the mainline LAMMPS version.
however, i am going to make a modification:
rather than defaulting all atoms to element "C",
i would have them by default have the current
naming scheme, i.e. the type number as default.
there are also a few additional subtleties that
need to be taken care of in order to maintain
full backward compatibility.
cheers,
Axel,
Of course, I don’t mind. Furthermore, my modification is based on dump_custom.cpp and there are no specific code in the modified dump_xyz.* files.
I’d be happy it to see it with your modifications in the mainline LAMMPS version
Grigory Smirnov.
2012/4/11 Axel Kohlmeyer <akohlmey@…43…4…>
Axel,
Of course, I don't mind. Furthermore, my modification is based on
files.
I'd be happy it to see it with your modifications in the mainline LAMMPS
version
ok. the adjusted version with full backward compatibility is now
in LAMMPS-ICMS. I've also added documentation and changed
the xyz comment line (the second line of each frame) to include
the time step numbers which should be a useful addition.
cheers,
