Greetings,
I was testing an atom style and I was wondering how I could alter the data file so the line of properties for a single atom can be really long. It seems that when I define the atom style propeties list past a certain line length properties aren’t picked up and the incorrect atom format error is triggered.
Greetings,
length properties aren't picked up and the incorrect atom format error is
triggered.
there is a define called MAXLINE in read_data.cpp that sets the
maximum number of characters per line.
you'd have to change it and recompile to make it handle longer lines.
please note, that there is rarely a good reason to add properties to
atom styles (and thus implement new atom styles), since you can also
use fix property/atom for that purpose without changes to sources.
Thanks, that worked. I looked into that but since every atom has its own set of interpolation variables in this style and there’s also a pair style and fix that needs to interface with it I decided to just make it.
