LAMMPS simulation where I have the following atom types,
Na ion: type 7
O atom of TIP3P water: type 9
H atom : type 8
Below is a part of the LAMMPS output (dump file) for four representative atoms
#lammps
1544 7 0.308291 0.550004 0.930876 0 -1 -1
1545 9 0.428824 0.888473 0.48709 -2 -1 0
1546 8 0.432441 0.882404 0.482596 -2 -1 0
1547 8 0.433352 0.892845 0.478202 -2 -1 0
I want to wrap all atoms around a specific group of atoms and I use the pbc wrap command, in the vmd console as given below
pbc wrap -center com -centersel “resname CNT” -all
after that i save the co-ordinates in lammpstrj file type and part of the saved co-ordinates is as given below
#vmd
1544 9 -9.38336 7.07769 30.9057
1545 7 -0.558907 54.9855 -1.58466
1546 8 -0.294113 54.1265 -1.91368
1547 8 -0.227417 55.6043 -2.23537
here I observed that the atom type 7 and 9 are interchaged as shown above. however the co-ordinates remain same on the files.
Could you suggest, what may be the reason and how to resolve?
Thanks & Regards
Na ion: type 7
H atom : type 8
atoms
#lammps
pbc wrap -center com -centersel "resname CNT" -all
this is a VMD not a LAMMPS question. please post it to the vmd-l mailing
list.
I don’t know about the VMD part, but the LAMMPS
dump command gives you options about dumping
wrapped vs unwrapped coords.
I don't know about the VMD part, but the LAMMPS
but LAMMPS doesn't allow you to change the center that things are wrapped
around let alone have it be defined as the center of a group or keep
molecules intact while wrapping and so on as the pbctools plugin in VMD
does.
