Summary
When trying to run a structure optimization, newer atomate versions throw monty error when doing loadfn(zpath("custodian.json"))
during the FWAction
update.
Test code used to generate the wf:
from pymatgen import MPRester
from atomate.vasp.workflows.presets.core import wf_structure_optimization
structure = mpr.get_structure_by_material_id(‘mp-1’)
wf = wf_structure_optimization(structure)
lpad.add_wf(wf)
Stacktrace from running
/projects/matqm/synthesis/cenv/lib/python3.4/site-packages/pymatgen/init.py:89: UserWarning:
Pymatgen will drop Py2k support from v2019.1.1. Pls consult the documentation
at https://www.pymatgen.org for more details.
at https://www.pymatgen.org for more details.""")
/projects/matqm/synthesis/cenv/lib/python3.4/site-packages/pymatgen/io/cif.py:44: UserWarning: Please install optional dependency pybtex if youwant to extract references from CIF files.
warnings.warn(“Please install optional dependency pybtex if you”
ERROR:custodian.custodian:
{ ‘actions’: [ { ‘action’: { ‘_set’: { ‘ISYM’: 0}},
‘dict’: ‘INCAR’}],
‘errors’: [ ‘rot_matrix’],
‘handler’: <custodian.vasp.handlers.VaspErrorHandler object at 0x2b80de941ac8>}
/projects/matqm/bin/vasp.std: no process killed
File “/projects/matqm/synthesis/cenv/lib/python3.4/site-packages/fireworks/core/rocket.py”, line 262, in run
m_action = t.run_task(my_spec)
File “/projects/matqm/synthesis/cenv/lib/python3.4/site-packages/atomate/vasp/firetasks/run_calc.py”, line 207, in run_task
return FWAction(stored_data=loadfn(zpath(“custodian.json”)))
File “/projects/matqm/synthesis/cenv/lib/python3.4/site-packages/monty/serialization.py”, line 82, in loadfn
return json.load(fp, *args, **kwargs)
File “/opt/python/lib/python3.4/json/init.py”, line 268, in load
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File “/opt/python/lib/python3.4/json/init.py”, line 312, in loads
s.class.name))
TypeError: the JSON object must be str, not ‘bytes’
INFO:rocket.launcher:Rocket finished
The same problem persists when using any structure.
The end of this stacktrace makes it appear the problem is with the JSON library. After looking into it some more, it is a problem with
particularly that loadfn
doesn’t seem to work on a zipped json file?
Using atomate 0.7.7 with an identical workflow and configuration works fine. It appears the problem might be related to Github issue #231.
System
- Distribution: CentOS release 6.6 (Final)
- Linux kernel 2.6.32-696.18.7.el6.x86_64
- Python 3.4.2
Python package versions from pip list
Package|Version
atomate|0.8.4
certifi|2018.11.29
chardet|3.0.4
Click|7.0
custodian|2018.8.10
cycler|0.10.0
decorator|4.3.0
FireWorks|1.8.2
Flask|1.0.2
flask-paginate|0.5.1
gunicorn|19.9.0
idna|2.7
itsdangerous|1.1.0
Jinja2|2.10
kiwisolver|1.0.1
MarkupSafe|1.1.0
matplotlib|2.2.3
monty|1.0.4
mpmath|1.0.0
networkx|2.2
numpy|1.15.4
palettable|3.1.1
pandas|0.22.0
pip|18.1
pydash|4.7.4
PyDispatcher|2.0.5
pymatgen|2018.11.30
If anyone else has had similar issues, I’ll make a bug report on the repo, and we should look into why the tests are not catching this problem.
