Thanks for quick reply,
I equilibrated crystal at 300K with periodic boundary condition. now I used last dump configuration of equilibrated crystal and want to heat up to around 1500K. but during this, I used fix wall/refelct command.
boundary f f p
fix 11 all wall/reflect xlo EDGE xhi EDGE ylo EDGE yhi EDGE units lattice
I can use that command if and only if I have fix boundary condition in a certain direction on which I want to apply that command. The problem is when I start my simulation, it shows that my atoms are lost.
sorry i reply personally.
Date: Mon, Jul 17, 2017 at 7:05 PM
Subject: Re: [lammps-users] atoms lost even i used fix wall/reflact command
To: Axel Kohlmeyer <[email protected]>
boundary f f p
if you want to have fixed boundaries, why don't you start with them right away?
you are making your life needlessly complicated. when changing
boundary conditions, you will need to re-equilibrate, so your previous
periodic equilibration is mostly a wasted effort.
also, in your original e-mail you said that you wanted to keep x- and
y- dimensions constant and let the system expand in z-direction.
this is _not at all_ what you are inducing by making the changes you
did. your changes set up a completely different system, i.e. rod that
is replicated in z-directions (but still with fixed box dimensions).
why don't you just keep all periodic boundaries and apply fix npt and
couple it only to the z direction?
regardless of whether you have fixed boundary conditions or periodic
boundary conditions, the box dimensions are unchanged unless you issue
a command or fix that can change them. perhaps you need to read up
some more about what boundary conditions mean in LAMMPS.
