Dear LAMMPS community
I am senior lecturer at Liverpool John Moores University (UK) and would be glad if you could help me with a LAMMPS issue.
I am trying to run a NVT simulation of a Silver-Gold alloy (86000 atoms, 20% of Au) using the respective EAM potentials (universal 3, distributed in the potentials directory of lammps). I know that when we use two different metals combined in an alloy, the EAM parameters for the alloy are automatically generated by standard mixing rules (the best approach would be to have the alloy-EAM potential already parametrized for the Ag-Au alloy, but I don’t find it). The problem is that, although I begin with a nanoalloy well centered on a cubic box (18 nm of side) and which shows a clear first RDF peak of Au-Ag at 2.9 Angstroms, after I start the simulation even at low temperature, atoms begin to strongly overlap, until they get as close as 0.1 Angstroms (revealed by the RDF analysis as well as by visual inspection using VMD of the trajectories file). Also, my simulation finishes normally without any errors. Would it be necessary to use SHAKE to prevent atoms from coming so close during the simulation? Or perhaps the repulsive part of the EAM potential only works for pure Ag or pure Au nanoparticles? Adopting the same procedure to simulate Au-Pt alloys by combining two different individual EAM potential files works fine…
I am running the calculation on a MacPro (24 logical cores) using mpirun with 24 logical cores and my input is shown below:
boundary f f f
read_data coordinates
pair_style eam
pair_coeff 1 1 Ag_u3.eam
pair_coeff 2 2 Au_u3.eam
run_style verlet
thermo_style custom step temp press pe ke etotal
min_style sd
minimize 1.0e-8 1.0e-6 10000 10000
dump 2 all xyz 100000 trajectories.xyz
dump_modify 2 element Silver Gold
timestep 0.00001
velocity all create 2 158379 mom yes rot yes dist gaussian
fix 1 all nvt temp 2 2 0.001
thermo 1000
run 10000000
unfix 1
undump 2
Thanks in avance
Rodrigo
Dr. Rodrigo Q. Albuquerque, BSc MSc PhD FHEA
Senior Lecturer in Physical Chemistry
Tel: +44 (0) 151 904-6287
Web: www.labsuprachem.com
E-mail: R.Q.Albuquerque@…7203…
Address:
Byrom Street, James Parsons Building (R. 2.03b)
L3 3AF Liverpool, UK
