atoms run apart while they are relaxing
Dear All,
I tried to relax the system of silicon nitride and PTFE(polymer with the elements of C and F).unfortunately ,while the system is relaxing , the atoms belonging to Si3N4 is running apart as shown below. And the PTFE was supposed to be adsorbed to the Si3N4 surface ,but it didn’t.
it is strange for me because the temperature I set is not high and the potential is fine to my system I guess.
Below is my input file. Hopefully some one can shed light on this problem.
Thank you in advance
Yours sincerely
Tina
units real
boundary p p f
neighbor 0.8 bin
atom_style full
neigh_modify delay 5 one 5000 page 1000000
pair_style hybrid tersoff lj/cut/coul/long 12
bond_style class2
read_data PTFEpackmol.data extra/atom/types 2
read_data si3n4command.data add append offset 2 0 0 0 0 group si3n4 shift -10 -17 20
pair_coeff * * tersoff Si3N4.tersoff NULL NULL N Si
pair_coeff 1 1 lj/cut/coul/long 0.054 4.01
pair_coeff 2 2 lj/cut/coul/long 0.059 3.2
pair_coeff 1 2 lj/cut/coul/long 0.056 3.61
pair_coeff 2 4 lj/cut/coul/long 0.107 3.825
pair_coeff 2 3 lj/cut/coul/long 0.0623 3.635
pair_coeff 1 3 lj/cut/coul/long 0.059 4.4
pair_coeff 1 4 lj/cut/coul/long 0.101 4.23
kspace_style ewald 1.0e-5
kspace_modify slab 3.0
region ptfe block INF INF INF INF INF 20
group ptfe region ptfe
compute tep all temp
velocity all create 300 987098 temp tep
fix 1 all nvt temp 300 300 100
fix 2 all temp/rescale 100 300 300 0.01 1
fix 3 si3n4 setforce 0 0 0
timestep 0.1
thermo 100
dump 1 all custom 100 nvtxyz.lammpstrj id type x y z
run 18000
Have you modified the parameters in the Tersoff potential file according to the real units used in your main script?
Bruce
Huijie Tang <[email protected]…127…> 于 2019年6月23日周日 10:10写道:
there are several problems with this input:
  1. you are choosing real units, but tersoff style potentials in LAMMPS usually use metal units. this is rather irrelevant, since you are using fix setforce to set all resulting forces for the atoms set to interact via tersoff to zero.
  2. however, fix setforce 0.0 0.0 0.0 is not sufficient to immobilize atoms. you also need a velocity of zero for those atoms. but that is not the case here. so those atoms will keep moving at constant velocity (no forces means no change of velocity)
  3. you are using two thermostats on the same atoms. that is a very bad idea. don’t use fix temp/rescale, anyway. it is bad for any serious calculation.
Dear Axel,
I am so sorry to reply you individually just now cause it was my first time to find help in mail list and i will pay more attention to it in the future. and thanks a million for your detailed and useful reply again !
Acoording to your suggestion, I modified my input but the atoms belonging to Si3N4 still run apart. Would you mind pointing out the mistakes in my current input ? The picture and current input are as follow.
Thank you in advance !
boundary p p f
neighbor 0.5 bin
atom_style full
pair_style hybrid tersoff lj/cut/coul/long 5
bond_style class2
pair_coeff * * tersoff SiNCkrollm.tersoff NULL NULL N Si
timestep 0.001
thermo 100
run 1000
you haven’t addressed all the issues i pointed out. issue 2) still applies. axel.
