Dear LAMMPS developers,
I have been trying to calculate the neighbor lists using the command lmp.extract_atom(‘x’) while running lammps with python. I have an initial structure of a periodic bilayer system, for which I am calculating the intra-layer and interlayer neighbours within a cutoff distance for each of the atoms. After calculating the neighbour lists, when I print the central atom positions and their neighbors, I noticed that, some of the central atoms are replaced with their periodic replicas. I need to maintain the initial structure that I started with, and get the neighbour lists based on this intitial structure, since the atomic environment around each atom is important for my job.
Can you please suggest me how to get the neighbour lists without changing the initial structure?
Note: I am calculating just the neighbor lists by running the minimization with single run.
lmp = lammps()
lmp.commands_string(“”"
atom_style full
read_data Initial_structure.mol
newton on
pair_style hybrid rebo zero 10.0 full
pair_coeff * * rebo CH.rebo C C
pair_coeff 1 2 zero
neighbor 2 bin
min_style fire
minimize 0.0 0.0 1 1
x = lmp.extract_atom(‘x’)
Thanks in advance.
