Pymatgen root imports will be removed in v2022.0.0 in preparation for a change to a more modular, extensible architecture that will allow more developers to contribute.
Specifically, the following “convenience imports” have been removed in favor of
their canonical import:
from pymatgen import Composition # now "from pymatgen.core.composition import Composition"
from pymatgen import Lattice # now "from pymatgen.core.lattice import Lattice"
from pymatgen import SymmOp # now "from pymatgen.core.operations import SymmOp"
from pymatgen import DummySpecie, DummySpecies, Element, Specie, Species # now "from pymatgen.core.periodic_table ..."
from pymatgen import PeriodicSite, Site # now "from pymatgen.core.sites ..."
from pymatgen import IMolecule, IStructure, Molecule, Structure # now "from pymatgen.core.structure ..."
from pymatgen import ArrayWithUnit, FloatWithUnit, Unit # now "from pymatgen.core.units ..."
from pymatgen import Orbital, Spin # now "from pymatgen.electronic_structure.core ..."
from pymatgen import MPRester # now "from pymatgen.ext.matproj ..."
If your existing code uses from pymatgen import <something>
, you will need to make
modifications. The easiest way is to use an IDE to run a Search and Replace.
First, replace any from pymatgen import MPRester
with
from pymatgen.ext.matproj import MPRester
. Then, replace
with from pymatgen.core import
. Alternatively, if you
are using a Mac command line, you can do:
find . -name '*.py' | xargs sed -i "" 's/from pymatgen import MPRester/from pymatgen.ext.matproj import MPRester/g'
find . -name '*.py' | xargs sed -i "" 's/from pymatgen import/from pymatgen.core import/g'
From a Linux command line, you can do:
find . -name '*.py' | xargs sed -i 's/from pymatgen import MPRester/from pymatgen.ext.matproj import MPRester/g'
find . -name '*.py' | xargs sed -i 's/from pymatgen import/from pymatgen.core import/g'
This should resolve most import errors and only a few more modifications may
need to be done by hand.
See the change log for more information on pymatgen changes and compatibility for planned changes.
