beginners question nvt integegration
Dear LAMMPS users and devs,
a short beginners question:
If I set up integration with:
fix integrator all nvt temp 3.0 3.0 0.5
can I than check quality of simulation with
variable cq equal etotal+f_integrator/atoms
as it is the conserved quantity mentioned in the papers for nhc integration?
Norman
See the fix_nh.html doc page for info on this.
E.g.
The “fix_modify”_fix_modify.html {energy} option is supported by these
fixes to add the energy change induced by Nose/Hoover thermostatting
and barostatting to the system’s potential energy as part of
“thermodynamic output”_thermo_style.html.
Thanks for the quick answer.
Is this equivalent to what I used to do?
What if I want to look at the potential energy of the physical system alone?
Is it better to use
"variable cq equal etotal+f_integrator/atoms"
without "fix_modify integrator energy yes"
or
"variable pephys equal pe-f_integrator/atoms"
with "fix_modify integrator energy yes"
I normally use the potential energy to see if the system has reached
equilibrium, since it seems to relax slower to it's equilibrium value
than other quantities.
Thanks again.
I don’t know what’s “better” for what
you are looking for. I suggest you experiement
with the different options and examine the output.
