Benzene fix rigid
Dear lammps users,
I am trying to simulate Benzene molecule (only one).
I know that I can use ‘fix shake’ command for molecule within 4 atoms.
So, I am trying to use ‘fix rigid’ command to fix atoms of benzene.
But, I cant hold benzene ( it moves differently, not together).
Any suggesiton ?
Units
units real
Resion
Force type
atom_style full
pair_style lj/cut/coul/cut 9 12
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
improper_style cvff
Atom definition
read_data data_1Benzene.txt
velocity all create 298.15 8343 dist gaussian units box
Neighbor list
neighbor 2.0 bin
neigh_modify every 10 delay 0 check yes
Calculation
thermo_style custom step pe ke etotal temp press vol density
thermo 10
Minimization
minimize 1.0e-5 1.0e-7 1000 100000
Timestep
timestep 1
Fix molecular
group Benzene type 1 2
fix 1 Benzene rigid molecule
Dynamic type
fix 2 all npt temp 298.15 298.15 100 iso 1 1 100
Variable
variable fs equal 1*step
variable density equal “density”
variable vol equal “vol”
Print density
fix 3 all print 10 “{fs} {density}” file fsDensity.txt screen no
fix 4 all print 10 “{fs} {vol}” file fsVol.txt screen no
Dump
dump 1 all xyz 10 dump.xyz
dump_modify 1 element C H
Start running
run 10000
Save the restart file
write_restart restart1Benzene.txt
You cannot minimize rigid objects with minimize. It will not respect the constraints and the atoms can freely move away from each other. If you need to minimize, you can use bond and angle potentials to keep them in place.
​or do simulated annealing.
axel.​
