I used LAMMPS to perform NPT simulations of bilayer graphene oxide in water.
The water model is TIP4P/2005 (Abascal, J. L. F. & Vega, C. *The Journal of
Chemical Physics* *123*, 234505-234512 (2005).)
Graphene edges is functionalized by hydroxyl groups. The initial
coordinates of chemical groups are taken from previous DFT study (Yan,
J.-A. & Chou, M. Y. *Physical Review B* *82*, 125403 (2010).). The force
field for graphene oxide I use in MD simulations is OPLS-AA.
The time step is 0.1 fs. The total simulation time is 100 ps. The
boundaries in three directions is all periodic.
The ensemble is NPT of 298K thermostat and 1atm isotropic barostat.
(fix 4 all npt temp 298.0 298.0 100.0 iso 1.0 1.0 1000.0)
The initial state is a non-equilibrium configuration. The two layers of
graphene oxide tend to be stuck together. The remaining space should be
filled by surrounding water molecules. However, a large vacuum hole emerges
and the simulation box won't contract its size to decrease the vacuum hole.
The attached PNG images are the initial and final frames of my simulation.
The formation of the vacuum hole seems to be unrealistic. Is there anyone
have the same problems in non-equilibrium simulations within water
molecules? I am wondering how to resolve this issue.
I found a paper (Patel, R. Y. & Balaji, P. V. *The Journal of Physical
Chemistry B* *109*, 14667-14674 (2005)) raise a question for different MD
results of isotropic and anisotropic pressure coupling methods. I can
change my pressure coupling method from "iso" to "aniso", which the xyz
pressures are "couple none". (fix 4 all npt temp 298.0 298.0
100.0 aniso 1.0 1.0 1000.0). Is it the key to solve this problem?
Thank you in advance.
-Wenpeng
The input script and log file of my simulation are attached as below:
########### input script ##########
# System and potential definition
units real
atom_style full
# processors 2 2 2
read_data ./data.GO-WM
# Pair Coeffs
