I want to generate a initial state of amorphous metal , while keeping two composition in a specified ratio, such as A30B70. However, when two type of atoms are created by ‘create_atom random’ , I have to use “delete_atoms” command to prevent error form overlap atoms, and then I found I can’t keep two composition in an exact ratio. Is there any other LAMMPS commands help me to realize it?
me to realize it?
there are two obvious options:
1) how about creating atoms with only one atom type initially,
removing the overlaps, and then using the set command with
type/fraction to convert a fraction of atoms to the second type
2) don't remove overlaps by delete_atoms, but do a short initial
simulation with pair style soft while slowly rising the repulsive
potential with fix adapt. similar as in the micelle example. then
switch to your originally intended potential
option 2 is a bit more complex, but has the benefit that you not only
control the ratio of atom types, but also the density, which isn't
given with your current process.
