Hi Lammps users, I am trying to parametrize Tersoff potential for BN using the values from
values are from Moon et.al Physica B 336 (2003) 329-334 as below, however, when I run my simulation using the potential values, I do not even get close to the minimum energy graph. I have included my input file as well. Anyone with some insight on what I maybe doing wrong, I would appreciate your input. Thanks
Jean Njoroge
these entries are in LAMMPS “metal” units:
A,B = eV; lambda1,lambda2,lambda3 = 1/Angstroms; R,D = Angstroms
format of a single entry (one or more lines):
element 1, element 2, element 3,
m, gamma, lambda3, c, d, costheta0,
n, beta, lambda2, B, R, D, lambda1, A
B B B 3.0 1.0 0.0 0.5269 0.001587 0.5
3.99290 0.000001601 1.38190 171.290 1.95 0.15 1.728 223.10
B B N 3.0 1.0 0.0 0.5269 0.001587 0.5
0.00000 0.000000 2.040950 0.000 1.95 0.15 3.582 0000.0
B N B 3.0 1.0 0.0 0.5269 0.001587 0.5
0.00000 0.00000 1.3819 0.0000 1.95 0.15 1.728 0000.0
B N N 3.0 1.0 0.0 0.5269 0.001587 0.5
1.330 0.0052938 2.040950 209.3237 1.95 0.15 3.582 1191.704
N B B 3.0 1.0 0.0 20312.0 25.510 -.562
1.330 0.0052938 2.040950 209.323789 1.95 0.150 3.582 1191.704
N B N 3.0 1.0 0.0 20312.0 25.510 -.562
0.00000 0.0000 2.70000 000.00 1.95 0.15 5.437 0000.0
N N B 3.0 1.0 0.0 20312.0 25.510 -.562
0.00000 0.0000000 2.040950 000.00 1.95 0.15 3.582 0000.0
N N N 3.0 1.0 0.0 20312.0 25.510 -.562
1.330 0.005293800 2.7000 511.760 1.95 0.15 5.437 6368.140
log log.cBN
#log file name
shell rm out.data
variable latt0 equal 3.49769 #Lattice parameter of Boron Nitride “Reference lattice constant 3.609 A” vary lattice betwwen
variable max_iter equal 1001
variable shift_i equal ceil({max_iter}/2.0)
label loop
variable i loop {max_iter}
if “i > {max_iter}” then “jump in.equillatt_bulk_mod”
variable j equal i-{shift_i}
variable latt equal ${latt0}+$j/1000.0 #Vary lattice constant in increments on 0.001
#-------------INITIALIZE SIMULATION---------------------------------------
clear
atom_style atomic
atom_modify map array
newton on
#number of cpus in x y z dimensions
#processors 1 1 1
#-------------CREAT ATOMS-------------------------------------------------
lattice custom ${latt} a1 1.0 0.0 0.0 a2 0.0 1.0 0.0 a3 0.0 0.0 1.0 &
basis 0.0 0.0 0.0 basis 0.5 0.5 0.0 &
basis 0.0 0.5 0.5 basis 0.5 0.0 0.5 &
basis 0.25 0.25 0.25 basis 0.75 0.75 0.25 &
basis 0.75 0.25 0.75 basis 0.25 0.75 0.75
region box block 0 5 0 5 0 5 #setup 1 region
create_box 2 box #create box with 1 region and 2 atoms
create_atoms 1 region box basis 5 2 basis 6 2 basis 7 2 basis 8 2
#-------------DEFINE INTERATOMIC POTENTIAL--------------------------------------------
mass 1 10.80
mass 2 14.00
include potential.mod
#------------DEFING AUXILLARY VARIABLES TO CONTAIN CHOESIVE ENERGY AND OUTPUT DATA--------------
variable EPOT equal pe
variable NP equal atoms
variable ELAT equal pe/{NP}
variable VOL equal vol
variable rho equal {NP}/{VOL}
variable AtomVol equal {VOL}/${NP}
min_style cg
minimize 1e-25 1e-25 5000 10000
shell echo {latt} {rho} {AtomVol} {EPOT} {ELAT} {VOL} >> out.data
next i
jump in.equillatt_bulk_mod loop
label break
variable i delete
