bond atoms missing on proc error
Dear fellow users,
My simulations ended with the error: both bond atoms missing on proc. I know it means that “typically this is because the pairwise cutoff is set too short or the bond has blown apart and an atom is too far away”.
I did some research, but I really have no clue what went wrong. My system has 4096 atoms. Two of them are methane, and the rest are water. The two methanes are bonded. And
a special_bond command was used to calculate pairwise interaction between the two methanes. My major concern is the bond length, which ranged from 8.4-16.4 angstrom. Do you think the bond length is the reason
that simulations keep failing?
My input file is as below:
variable k equal 1
variable Ro equal 13.4
variable dx equal x[1]-x[2]
variable dy equal y[1]-y[2]
variable dz equal z[1]-z[2]
variable bx equal xhi-xlo
variable by equal yhi-ylo
variable bz equal zhi-zlo
units real
atom_style full
special_bonds lj/coul 1. 0. 0.
pair_style hybrid sw0 sw
bond_style harmonic
read_data data.4094w_2methanes5A
newton on
pair_coeff * * sw0 mW-methane.sw Si Ge
pair_coeff * * sw mW-methane.sw Si NULL
neighbor 3.0 bin
neigh_modify every 2 delay 4 check yes
timestep 5
thermo 2000
thermo_modify flush yes
velocity all create 300 4928459 rot yes dist gaussian
fix 5 all nvt temp 300 300 1000
#dump 1 all custom 10000 nvt-300K.lammpstrj id type xs ys zs
fix scales methane print 100 ‘{dx} {dy} {dz} {bx} {by} {bz}’ file scales.${Ro}-$k screen no
restart 500000 restart_300K
run 5000000
write_restart restart.end_300K
Thank you.
Bin
Dear fellow users,
it means that "typically this is because the pairwise cutoff is set too
short or the bond has blown apart and an atom is too far away".
you cannot have a bond that is longer than the largest non-bonded
cutoff plus "neighbor list skin" distance.
if you need a harmonic constraint between those two molecules,
you can use fix spring in couple mode with 0.0 0.0 0.0 as vector and
r0 as the equilibrium distance and k as the force constant.
