I have some queries regarding the bond/break command .
1. As it is documented in LAMMPS site :"This fix is part of the MC
package. It is only enabled if LAMMPS was built with that
package....Currently, there are 2 restrictions for using this fix".
So what exact package is required for this command to work with ?
2. Now,say,I have a system where 'the no of bond types'='no of bonds'.
And moreover all the bonds have different bond length.
For this case if I want to impose bond/break, I have to mention the
'bond-type' in the fix. Basically it has to be executed over all bond
types.then what value have to be written ?
Any comment is welcome.
Thanking you,
You need the 'mc' package. For instructions about how to build LAMMPS with optional packages (Linux):
http://lammps.sandia.gov/doc/Section_start.html#start_3_2
You can also play with 'make' in your source directory.
Thanking you,
Saikat Basu
Junior Research Fellow
Department of Solid State Physics
IACS,Kolkata
Kolkata-700032
Ph no- 03324734971(extn- 2114)
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
_______________________________________________
lammps-users mailing list
[email protected]
https://lists.sourceforge.net/lists/listinfo/lammps-users
I don't know 'bond/break', so I'll leave it to someone else to answer point 2.
Samuel Palato
For the second answer,
If you want to all bond types to be eligible then have the fix multiple times with different values of bond_type.
Regards
Vikas
